I have a script to create new integration key for 90 services, but it doesn’t seem like im able to make an api call to get a list of services and their integration key (I can only see the ids). I have another script to add the service name and integration key to Datadog. Id like to be able to pull a list of service names and the integration key, is there a way to do that?
Is there a way to pull integration keys from API
Yes, that is available when doing a GET on the actual integration object ID.
When passing include[]=integrations, the JSON response body will have one or more fields named integrations.XX.integration_key that contains the integration token key you’re looking for!
